0 gauge wire diameter
kronos
Hi,
I'm looking to buy some 0 gauge wire. I went to a local audio store and they have a 0 gauge wire that seems kind of cheap. It measures about 5/8" outside diameter and about 3/8" inside diameter . Can any of you guys tell me what will be a good inside diameter for a 0 gauge wire? thank you
So if it was 3/8 inside diameter it was about right.
The diameter I gave above was the national standard, and I believe it refers to solid wire only, so for stranded wire, perhaps the number should be slightly bigger? I'm not sure.
I think strand count only affects flexibility. However, if you can get the strand count, and the diameter of a single strand...then you can get overall cross-sectional area of the copper and compare it to the standard for solid copper wire.
Im not sure if this site is the same or the same price as it used to be, but the point is, welding cable can be pretty cheap, it doesnt look as sexy, but its usually quite flexible, and has plenty of copper...
I'm using the orange Ultra-flex from WeldingSupply.com and I'm very happy with it. It's 1/0 and limp like a noodle. As for the core, I actually had to give it a haircut to fit in my 1/0 terminals as it was a bit thicker than advertised. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I see the Kicker and Kollosus weren't added to the mix. Wonder why.
If you click on the picture, it will go to the direct link and list which wire is what brand and size.
2265826330048953316S425x425Q85.jpg'%20alt='2265826330048953316S425x425Q85.jpg'>
kronos
kronos
WISCONSIN
QtrHorse
