0/1 Gauge or 4 Gauge?
depends on how much more is the 0/1 gauge...if its a shitload more then just do 4 gauge...
i have 2 4 guage wires running from battery to distroblock and from that 1 8 guage running to 4 chan amp and 1 4 to a hifonics...works fine
if you can get 0/1 for close to the same price or a little more then do it so you don't have to upgrade later on...
0/1 gauge won't fit in a BX1000D. Atleast I don't think it will? I know all that fits in 1000D's is 4 gauge cause mine hardly fit. Make sure before you go buying any.
The Hifonics BX1000D only supports up to 4 guage wire inputs. If I were you I would see how much more the 0/1 guage is and if its not more than just run that to the amps location and then get a distrobution block and run 4 guage wire from the distro block to the amp. I myself though have 4 guage running to amps location and 8 guage wire to each amp, and I havent had a problem with it yet.
now with doing all this *i'm running the BX1500D and a Audiobahn 8002T* currently have 2 runs of 4gauge, 1 for each amp,
could that simply run of one 4gauge to a disto that puts out 8gauge *what i have somewhere* or should i stick with the 2 runs of 4,
i just threw the second 4gauge in over my carpet untill i could figure out if i REALLY needed 1/0, although i plan on doing the big 3 with 1/0 so would be cool to get some info here so i can order accordingly. //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
Mazda626
Mazda626
Ellensburg
JimJ
