Will this be enough port?
  • 6
Ridinhi
I thought in my head there had to be a sub that would actually fit in there. 21” voice coil, 573 pounds, LOL. It only needs a minimum 353 cubes of airspace. That’ll fit in my trunk, right?
If your trunk is a big u-haul truck 😂
Are they standing inside the enclosure? That is beyond crazy
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t reinforced enough to handle the pressure. The truck was literally tearing itself apart within a minute or so.
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
Ridinhi
Ridinhi
Winston-Salem, NC
dragon.breath
