Featured Sub LPF weird now on Alpine iLX-507
RConrad1976
Hey guys! I have a question. My Alpine ILX-507 is confusing me with the slope for the subwoofer. When I go into crossover setting with the crossover flat, when I go to set the slope it now moves to the slopes do like in the provided picture. Please excuse the glare and dirty display. I've been trying to figure this out for two days. I was accustomed to the blue slope would move right to left as the slope was increased now it's left to right.
It sounds like you're experiencing some confusion regarding the crossover settings and slope adjustments on your Alpine ILX-507. Let’s break down what you might be seeing and how to adjust it properly.
### Understanding Crossover Settings and Slopes
1. **Crossover Frequency**: This determines the frequency at which your subwoofer will start to play. Setting this correctly is crucial for balanced sound.
2. **Slope**: The slope (measured in dB/octave) indicates how quickly frequencies are attenuated above the crossover point. A steeper slope (e.g., 24 dB/octave) means that frequencies above the crossover point will be cut off more aggressively compared to a gentler slope (e.g., 12 dB/octave).
### Adjusting the Crossover Settings
1. **Accessing the Crossover Settings**:
- Go to the audio settings on your Alpine ILX-507.
- Navigate to ‘Crossover’ settings.
2. **Setting the Crossover Frequency**:
- Adjust the frequency where you want the subwoofer to start playing. A typical starting point for many subwoofers is around 80 Hz.
3. **Adjusting the Slope**:
- When you change the slope setting, the visual representation may look confusing. Make sure to check the manual for your specific model, as the graphical representation can vary.
- The slope will typically move left to right as you increase it, indicating a steeper slope. If it appears to be moving right to left, it may be a graphical representation issue or a misunderstanding of the interface.
### Troubleshooting Steps
- **Manual Reference**: Refer to the owner’s manual for the Alpine ILX-507 for visual diagrams of the crossover settings. These diagrams can often clarify how the adjustments will affect sound output.
- **Reset Settings**: If you’re unsure about the current settings, you can reset the crossover settings to factory defaults and start fresh.
- **Testing Different Settings**: After adjusting the crossover frequency and slope, take the time to listen to how changes affect your audio. Small adjustments can lead to significant differences in sound quality.
- **Check for Updates**: Ensure that your unit’s firmware is up to date, as sometimes updates can resolve bugs or improve functionality.
If any of these suggestions don’t resolve your issue, or if you’re still unsure about the slope adjustments, feel free to share more details or ask additional questions.
Also, if anyone else has experience with the Alpine ILX-507 and can offer their insights, please chime in!
Red is low pass (subwoofer)
80hz low pass everything below 80hz will pass through anything above 80hz will roll off according to your slope
6db is 6db per octave
a 24 db slope will be 24db per octave
Blue is high pass everything above 80hz will pass through
Everything below 80hz will roll off according to your set slope
RConrad1976
RConrad1976
Florida
supernov4
