Featured Gladen sub amp hook up.
my2006c6
Junior Member
Im a little confused on my new Gladen amp that came in today. I need to hook it up to my 1 sub which is wired for a 2 ohm load. Here is pic of the gladen diagram and a little confused on where to hook my neg n positive wire off my single sub to the amp so its @ 2 ohm.
Im assuming i hook my positive wire to channel 1 positive and my neg to channel 2 negative. or vise versa
Those 2 channels on your amp are connected together
4ohm coil on each side will result in a 2 ohm load
If you already wired you sub coils for a 2 ohm with 1 lead coming out
Just connect your lead to 1 set
The other set is more for convenience when using more woofers
I just finished hooking up ... So i hooked my positive wire to Left channel positive terminal,,, and my Neg wire to the Right Neg terminal . - Correct ?
Yes that will work
Think of both negative screws as 1 screw
Same with positive
It won't matter which you use
Just don't hook up another 2 ohm speaker to those terminals
That will give you a 1 ohm load etc
my2006c6
Junior Member
my2006c6
United States
supernov4
