Just sent you three of the best vids I know, from Resonix on how what and where to apply it for optimum effectiveness.Out far enough on the inner panel where the door speaker mounts, or get more random coverage through out the inner skin?
If you seal the holes with sound deadening material, you don't need the vapor barrier.Can you guys set me straight real quick on this, sound deadening, inner and outer door panels. Does the vapor barrier go back on after I sound dead, or leave it off?
It is, but the sound deadening helps with keeping the sound and the sound pressure in the door. Al though it is slight, there is a difference in the sound.Deadening is an expensive way to cover holes, high cost, zero benefit, vapor barrier is already paid for - just saying.
Rope or adhesive backed Neoprene.Where the black door handle bezel snaps into the door panel, I forsee a big rattle source! Going to take it apart but should I use Tessa tape to line both in that area, butyl rope, I also have some thinner foam matting I can use…
Don’t have butyl rope but can be easily sourced…
Thoughts?
Sideways pics again….
It's near impossible to get a rattle free door on the first try when you have a solid midbass driver.going to tear it down tomorrow & see what the overlap looks like...
I do have Tessa tape, 157mil closed cell foam,
dont think the butyl foil will be a good idea as will be too thick & interfere with it securely snapping back together.
can easily cheaply source butyl rope or even some neoprene rubber...
Really think that are is going to be a rattle trap.
Also these door panels dont snap in place with traditional push pins.
They have big boxy hooks same material of the panel, probably wrap those with Tessa tape, maybe Tessa tape, closed cell foam & more tape, try to keep the bulk down,
Just dont want the panels to rattle!!!!
