BrazilianBassBuster
Why do I want an openable subwoofer box?
The lack of space is the physical constraint that makes reproducing the lowest frequencies in a car so difficult. The 20-40 Hz waves are too long, so to tune the loudspeaker at this frequency we need a lot of air in the enclosure to act as a long mechanical spring.
Of course, loudspeakers with stiffer suspensions will require smaller enclosures, but then any decent car subwoofer already has a very stiff suspension. Well, we can double the stiffness of any loudspeaker if we use two units in an isobaric compound configuration. That will divide in half the enclosure space needed, but this won't help much in the 20-40 Hz for two reasons: (1) the port dimensions will remain the same (in this frequency range, port size may take even more space than the actual air spring space), and (2) an isobaric arrangement lowers the system's efficiency in 6 dB, so it requires quadrupled power to achieve the same result (4x), which you may not be able to provide, or your loudspeakers may not support.
Conversely, with doubled space for the sub-enclosure, we will gain +6 dB in efficiency. Usually, this is done by using two drivers side-by-side, which will also double your system's power handling and your air displacement potential, allowing an extra +3 dB if you double the power. This is why enclosure space is so important.
OK, but the car has lots of space, so what's the problem with using it? The problem is that the used space becomes unavailable for its original purpose. If the box uses the space from the back seats, then we can't have people sitting there. If it uses the trunk, then we can't carry objects there anymore. But what if we built a special box that could be opened to put stuff inside it? OK, I won't put people inside a subwoofer box, but maybe it is fine to put the spare tire inside it? Perhaps the 16-inch Dahon foldable bicycles and a foldable electric scooter?
How can the box be opened?
I have thought about 3 options:
Option A) A simple "trunk bed" system:
Option B) Use a "guillotine door" system to close the box:
Option C) A door that slides over the box, possibly made of glass:
Option D) A rounded small class lid that opens up:
(in reality, the curved glass in the above image is not openable, but you can imagine it opening up like in the previous image)
Initial thoughts:
Option A seems to be the easiest one to build. Because I can easily buy a ready kit with that metallic joint and the piston used to lift the lid:
I actually sleep in a bed that is just like the one in that picture.
However, all of the 3 ideas have the same challenge, which is to avoid vibration (resonance) and air leakage. In that sense, option D seems to be the most promising one. Because the curved glass is much better in holding resonance than the flat wood. Also, it allows me to create a box that goes up to the car's roof. And if another piece of glass is added on the back of the box, then I might still be able to use the car's rearview mirror. Just need to keep those glasses clean. And the curved glass is kind of easy to buy as well:
So, what are your thoughts about all of those ideas? Has anyone ever tried something similar?
Initial thoughts:
