Couple questions
josh7311
Hey all,
I've got a couple questions that may be stupid, but hey gotta start somewhere.
I've installed a amp and sub in my car. Skar amp 800w with a skar 18 1200w.
My first question is setting my gain. I don't have any fancy tools so it's gonna be set by ear. My question is how do I really dial that in? Let's say i use a specific song and i dial it in sounding good. Who's to say I play another song that has more or less bass so what do I really use to get that set??
Next question is can anyone tell me what my custom box is tuned to?? Or air space it is?
Dimensions
W-32
H-14
D-28
My speaker calls for 2.75 ft³ sealed @ 32HZ
I generally set my gains using the following method. Read your Head Unit manual to see how much voltage the RCAs put out and set the gain for that in the amplifier.
Some of the more experienced folks use a multimeter, or some other method.
Here's a decent video how to do it by ear
So basically where I'm going wrong is instead of a song just play a test tone, at the volume I like to listen to. But instead of 40HZ like he did, I would do whatever mine is.
I need to find what my box is tuned too and play that tone?
I've never done a second tone for the box tuning. I use a -3db 40hz tone personally
I've done it with a song before back in the day but you really need to know what the song should sound like and what you're hearing from the subs...and ultimately there a bigger risk doing it that way 😄
That's just the sweet spot and about where most amps are rated
Gotcha!
You think if I do that 40hz and tune it max before distortion then I ✌️should not✌️, have to think about blowing the sub if I never go over the volume that I did the 40hz test at.
Or I'm assuming I would still have to do little adjustments from songs to song like I'm doing now.
Oh also does it matter that I make my adjustments with the trunk open or closed? Reason I think of that is how bass is louder with windows open would the air make a difference
Gotcha!
Different songs are recorded at different levels...so you'll probably need to adjust your bass knob occasionally for different songs...as for blowing you sub, if you smell the coil or it sounds distorted back off the bass knob 😂
And be really really careful turning up the hu volume past where it was when you set the gain...
You'd probably need to set it with the trunk open unless that's not where the amp and sub are
Cool I appreciate all the info! Like I said probably some dumb questions but 🤷
josh7311
josh7311
oklahoma
spokey9
BP1Fanatic
    Jul 1, 2026
BP1Fanatic
    Jul 1, 2026
