Rockville 12D1 Destroyer
No,. Keep in mind, having the 1/0 in place just allows you to breath going forward. It affords you an upgrade path going forward. If you are considering improving the build incrementally then yes, definitely go the larger 1/0 OFC right off the bat.
The big three will help should you get a 2nd battery and have to run more equipment (it's not a bad idea at any rate). If your considering doing it all at once, then may want to buy your stock and connectors separately. these guys have pretty decent pricing on all colors/gauges of about any wire you can think of.
thank you for the information! would it make sense to get a rockville amp to go with the sub? would the rockville rxm s6 or db16 8k watt be sufficient?
No don’t get a Rockville amp, i smoked the 8000 watt back and blue one and I smoked a 6000 watt krypton. In the process of getting a Taramps 3000HD, the same one that was recommended to you, it makes 4100 watts rms on the dyno and has cooling fans
Scooby59
Scooby59
New Jersey
