In need of some help please. Trying to install an amp and sub into a 2016 terrain with pioneer system. Using an loc. Got power at the amp. Tapped into rear speakers. But not getting any sound form sub. Any help would be greatly appreciated.
Have you adjusted the gain on the LOC.Any help would be greatly appreciated.
I did. Somewhat. Just seems like I'm not getting anything from the rear speakers wires. Thank you for answering. Not sure what to try next. Maybe a different amp. But this one has power. Soo. Idk.Have you adjusted the gain on the LOC.
Ok. Yea. So maybe I need to tap into the factory sub? And thank you for replying!Probably no low freqs from where you're tapping. You need to get a full range signal at the head unit.
Yes but you will be limited to the factory tuning. You'd get more control with a fullrange signal.Ok. Yea. So maybe I need to tap into the factory sub? And thank you for replying!
Ok. Yea. Guess im just not sure were to tap into for the loc. Thank you for replying!Yes but you will be limited to the factory tuning. You'd get more control with a fullrange signal.
Can you get a 3.5mm to RCA patch cable? You can connect your phone to the amp for testing.Ok. Yea. Guess im just not sure were to tap into for the loc. Thank you for replying!
I used to have one... will try to find it. Thank you for replying.Can you get a 3.5mm to RCA patch cable? You can connect your phone to the amp for testing.View attachment 60403
