D4s jp63
I would e-mail d4s and explain to them what’s going on. It might be just a faulty bass knob. In my situation everything worked on bass knob but clip light was stuck on and amp would come on it never went in protect.ended up being The Bluetooth card failed on mine
Hi, my JP63’s Bluetooth bass knob stuck at “Scn”. It was working fine since 4 months. Now it is not connecting to the amplifier. Is this bass knob faulty or is fault in the amplifier?
I cannot recall the model number but another user with BT bass knob issues ended up opening the amp and "unplugging" the BT module. He said it was like a daughter board, so no soldering iron required.
i was wondering if you ever figured out how to get the knob out of scn. i just purchased a knob and opened it and as soon as i plugged it in it said scn i tried to press and hold button 3 seconds and no flashing light or anything, what do i do
How much watts to the amps? Make sure the watts matches with the radio you use. Match all the ohms, and the amps, since these are linear power amplifiers, they go up in increments. The power goes up constant functions. Find the correct amount is the key. If you have a 65 watts radio, then the amps you add maybe 250 watts, that is 3.8 to 4 times the power of the watts to the radio. Head unit. The linear power remains constant at 4. It will remain at 4 times the power throughout its voltage input and output readings. And not expect 2000 watts output. You probably have the wrong watts connected to your truck. Also this post is two years ago, I joined this forum under another name, 3 names, 4 names now, on June 2023. Now I'm under google sign up. But that still works too. Changed it 3 times, 4th time google took over the show. Hopefully this will be the last password I use. If not, change it like they have a menu for it. And last of all, how can you fix the amplifier? Easy. Take it to a electronic shop, they'll test it for you. Saturation mode, so shut down. They'll check to see if any mosfets are burnt out. If so, they'll change the mosfets, cut off the two leads, add a new one in the circuit. Nothing to it. Drain all the capacitors to the amp using a light bulb and neg and pos probes touching the two input leads of the circuit. OP AMP. Then test it again if it remains constant using another radio hook up and an oscillator. Sign waves in the correct amplitude. Then give it back to you. About $75 dollars repair fee for the electronics shop.​
Were you just purchase the JP bluetooth bass knob or the module separate? Have you tried to unplug the module from the amp board to see if that’s the problem? If your stuck on Bluetooth knob you can preorder LF Audio/AMP Lab, they are also teaming up with Ruthless audio amps
sbialek
sbialek
kentucky
Claire Pierson
