Featured 2023 Ford Maverick - Full Sound Digital GAN & Ground Zero SQ+
BRAX Matrix SQ
This is my 2nd custom SQ build created by Sound Evolution in Houston, TX. The system was built around (2) Sound Digital GAN 1500.5 Founders Edition Amps (#4 & #34) that I managed to get my hands on. I had the opportunity and pleasure of meeting up with the HKI USA Team (Sound Digital & Ground Zero) at MasterTech in Phoenix this past March when I was debuting my F250 Brax SQ build with Sound Evolution, MSC & Audiotec Fischer. We discussed what they recommended to tie into the 1500.5's for a high quality & fun SQ system and this is what I ended up going with for this build...
Primary Audio Components:
(2) Ground Zero GZNT28SQ - 1.1"
(4) Ground Zero GZNK80SQ-K - 3.15"
(2) Ground Zero GZNK165SQ-K - 6.5"
(1) Ground Zero GZHW8SPL-D2 - 8" Flat
(1) Ground Zero GZHW10SPL-D2 - 10" Flat
(1) Helix DSP Pro MK3
(1) Helix Conductor
(2) JY Power NXT-2KF Caps
Second Skin Deadening - Cab Multi-Ply & 3-Ply Door Treatment
The setup is a 3 way active stage in the front with rear fill. A Flat SPL 10" sub is in a ported enclosure which was built into the Hybrid battery tray system under the rear seat, drivers side. There is another Flat SPL 8" sub that is in a stealth ported enclosure up & under the dash in the passenger foot well. The system has volume, clarity and is very impactful. The most important part, it's super fun to listen to!!
Modifications Current & Upcoming
Drivetrain - Hybrid 2.5L
Interior
Current Mods: Black & Tan Leather w/ Custom Door Speaker Pods, A-Pillar Speaker Pods, Under & Behind Rear Seat Ported Box & Amp & LED Display, Passenger Footwell Stealth Ported Sub Box Vented through Dash, C-Pillar Stealth Speaker Pods
Exterior
Current Mods: Ceramic Tint w/ 10% Back Glass & Rear Windows, 25% Front Windows & 20% Panoramic Sun & Moon Glass, ClimArt In-Channel Wind Deflectors, BakFlip Bed Cover, Spray In Bed Liner
Lighting
Current Mods: LED Audio System Lighting
Suspension
Current Mods: Eibach Lowering Springs (3.5" R/2.5" F)
Upcoming Mods: Full Airbag System
Wheel and Tires
Current Mods: 20" Vossen HF-4T on 255/45ZRx20 Nitto NT555 G2
Security
Current Mods: Compustar T-13, IGLA PIN & a NDA
Build Photo
  1. Okay
Simply Space... it's a hybrid Maverick, so the battery is under the backseat on the passenger side. In order to utilize both of the 1000+W 5th channels on the GAN amps and to create a clean build without modifying or completely removing the battery & tool tray system. It was decided on 1 SPL Flat 10" to be built into the spare tire jack/tool compartment and the 1 SPL Flat 8" (per enclosure space requirements) fit perfectly under front passenger footwell that is ported under and through the dash.
BRAX Matrix SQ
BRAX Matrix SQ
Texas, USA
BRAX Matrix SQ
