Bass Louder and softer sometimes... Bass subwoofer problem - Bass loss
BassErex
Hello! From above, sorry from too long entry, I wanted to present my problem well. And I'm asking for advice :)
I have weird problem of bass from subwoofer. I fight with this about 4 years On two cars: Mazda 323f Ba and Mazda 6.
Sometimes bass is much better and softer. and sometimes i can feel better presure, but car body shake is the same. Mostly my bass sound is SH*T (sorry).
I see voltage, and if bass is very very nice, no diference with voltage drops ( Reading from amp terminal)
Voltage drops are small, so, its cant be a problem
My system on today:
Mazda 6 2007r Wagon 2.0.
Hifonics BRX 12000 + Audio System XIon 15-1000 (Wired 2 ohm)
Rodek 2180A + STX pa 1000 coppy on rear seats (Sorry, its not good but should not make problems, on mazda 323f ba the music was from the doors and this same problem)
My Head Unit is now alpine cde 178bt
My power:
- Lithium YINLONG 2 Packs (80ah) in trunk
-Alternator 300a (14,5 - 15,4V)
Wires Power:
- 2x 50mm2 from alt to batt (Sorry i dont know how Ga or Awg, I;m from polen) All wires 100% copper
- Sub Amp Hifonics 2x 50mm from terminalls (about 0,70m lenght)
- Rodek 1x 16mm2
Grounds Wires:
-1x 50mm2 from alt to chasis, and from chasis to batt
-1x 50mm2 from engine to chasis, and from chasis to batt
- 2x 50mm2 from battery to nearest chasis point
- Hifonics Grounds 2x 50mm2 is from lithium batt terminall, per ground wire is about 1,5M lenght (its problem? too long?)
Problem is going on this two amps, amp from music i have too diference with bass, are louder can be.
I checked:
- Grounds, looks nice
- Connections fuse, power wires, Sub speaker wires. (no lose)
-Rca connections on HU and amp, very tightly.
About this 4 years i tested:
Much amps (Emphaser ea 2500, Vibe Mono 21k, kicx ad 1.400)
Subs (2x 15 excursion sxx 15v2, Pa subwoofer, clarion sw 3012)
3-4 of PCS rca (I now from sub have Pride diamond)
Kenwood x7200dab Hu, and pioneer 3500ui.
Speaker wires.
Sometimes bass loud and soft can back but not always if:
I REconnect amp power
Change Port subwoofer (to lower or higher tuning)
Bass can back if i a few times put subwoofer to trunk, roof, trunk roof, trunk roof, can sounds be better.
Bass like run away, if most offen i restart engine.
Today i checked all connections, In sub box terminal very nice
tightened. Speaker wires are good.
I have a osciloscope, no distortions from hu and amps but:
My weird looks:
Volume on hu max 35
to 10 sound bass going up, 10 to 15 stop to sub, but music going up WFT?
I tried to see voltage output from hu, and i have problem to Get nice output voltage,
Cliping at 4,4v, but i put Preamp source USB is FULL, and i have full no cliped voltage about 4 volts on 32-33V on radio with Bass boostloudness off and flat EQ.
On aux From my xiaomi on full preamp source on hu, i have on good music max 1,2v.
I Set my gains property clean, with full clean voltage output Hu, but with sound quality and hitting bass, no diferences...
Any questions? Too long grounds amps? Thanks.
Hi, i dont have front battery, all audio equipent is connected to the battery in trunk.
Have you tried running a ground from the main battery to the back, where the amp is? You don't ground it to the amp. You just ground it to the point where the amp is. Also, if you have a battery isolator, it might be interfering as well.
Have you also tried grounding the shielding on your RCA's?
  • Jun 15, 2023
Hopefully, in the last year, he got it all figured out! ;)
I checked exactly what it looks like, its only a weird output from amplifier. Engine off, rca unpluged on amp, speaker wires unpluged, and.. I have 0,512 volt noise, (sometimes about 420 hz sometimes above 800 hz noise). If i start engine or plug rca, nothing change, i have too this noise, DC output on 0,3 volt drop on music is about 0,2 volts on my amp! lol. What to do in such a case?
Uptade: since I started using a ''good'' resistance meter. on my side it is UNIT 204+ i see loosing performances.
Resistance beetwen SUPER CAPS and MY amp input is with off system 1 ohm, amps on 13 ohms, on playing music with 0,3v drop i see 80-300 ohms!!! sometimes ground be okay and high resistance go to + wires.
The problem: Conncector on a connector is loose several ohms. And next problem is wires, between connector from supercaps and to cable sleve i read 5 ohms with only amp on!!! (37% loose power)
This is a connection loss issue. search only with reading resistance to fix problem!!!
BassErex
BassErex
Poland
BassErex
