Help. 10W7-3 slsingle sub. Best amp??
KcContractor
I have a single 10” JlW7-3 in the red eye box. I want a really high quality amp that I can find pre-owned for a good price… what are the best ones you would recommend and why?
factory specs:
Continuous power handling 750W RMS
(1500W Peak Power)
3 OHM Mono
Frequency 20-250 Hz
I run these and the EXL line from DS18, their Korean board amplifiers. THey are solid performers. The Hooligan H-KO2 puts out the right amount of juice at 3 ohms to accommodate you currently and plenty more should you add another sub.
Used/shipped $329 (new $550)
  • RMS Power @ 4 ohm: 950W
  • RMS Power @ 2 ohm: 1500W
  • RMS Power @ 1 ohm: 2000W
  • RMS Power @ 0.5 ohm: 3600W (Burst)
  • Frequency Response: 13-300Hz
  • Signal To Noise Ratio: More than 80dB
  • Efficiency @ 4ohm: 95%
  • Damping Factor: 400
  • Total Harmonic Distortion (THD): Less Than 0.2%
  • Low Level Input Range: 0.2-6V
  • Selectable X-Over: Fixed LPF
  • X-Over filter Range: 35-250Hz
  • Bass Boost Range: 0-9dB
  • Bass Boost Frequency: 45Hz
  • Infrasonic Filter: 10-50Hz
  • Phase: 0-180
  • Power Input Terminal Size: 0GA x 1
  • Fuse Size (recommended): 180A (Not Included)
  • Dimensions (LxWxH): 10.62″ x 9.68″ x 2.85″
  • Phase: 0-180
Thank you!!! It looks great!
  • Phase: 0-180
Would running it at 4 ohm 950 RMS be ok for the sub even thought the specs recommended 750 RMS?
You're fine. You will run it at 1.5 ohms most likely. That is both coils wired in parallel to a single amp output.
EDIT:
Doesn't apply on a single 3 ohm VC sub, sorry.
  • Phase: 0-180
Ok, now that makes sense. Thank you!!
See how badly I need help lol. I don't know what I'm doing. I'm definitely going to seek help with install and hoping you guys can point me in the right direction of the best possible amp used or new in the $300 range
You have an endless amount of choices in your price range. It really comes down to what specific criteria you have. For example, is the size of the amp a big factor in your choice cause space is limited? Do you want to go with a half bridge style amp or a full bridge type? Do you have a color preference on the amplifier? Do you need good quality onboard Xovers? Due to the subwoofer being an oddball 3 ohm and everything these days making power at 1 ohm, that kind of sucks lol. You have to buy a pretty powerful amp so that it gets you decent power at 3 ohm. If you go for the Korean half bridge amps, this can be a little pricey and if I was in your shoes, if I’m gonna spend the money I’m gonna want the better of the Korean offerings. If that’s the case I’d go for something built by Zenon factory, brands that use that factory are ampere audio, amp lab, incriminator audio, crescendo etc. If you are open to full bridge amplifiers which are more efficient a taramps would do the trick but the onboard Xovers are junk. These also tend to not like low voltage but in your application I highly doubt you will even get close to that. Good news you can buy brand new and be under $300 🥳. If im not mistaken, your sub is a single 3 ohm, not a dual 1.5 ohm so 3 ohm is your only option 🥺
The JL is a great amp, and yes, you pay for it too. If you are planning on anything down the line, you will need to consider that too. I don't think you can go wrong with any of these configurations as long as you are aware of the limitations. The JL comes in a little underpowered in this group.
Ah, was just going to check on that. Single 3 ohm. For the money and to get the most out of this sub, get the H-KO2, puts out about 1200 watts at 3 ohms. Turn down the gains a bit, you'll have loads of power and your amp will not work hard to get you there.
Well, I only understood about 75 percent of what you were saying. I would like something that takes up as little space as possible without compromising the sound quality. In a perfect world it would be black or red but that really doesnt matter much to me. I'm not sure about the meaning of the half bridge and full bridge are tbh.
Thanks Doxquzme
KcContractor
KcContractor
Olathe, KS
djdilliodon!
