Different ohms on subwoofers.
On the 2 Ohms sub, connect the positive of one coil to the negative of the other coil. Connect the remaining terminals to the amp. On the 4 Ohms sub, connect the coil 1 positive to the coil 2 positive and the coil 1 negative to the coil 2 negative. Then connect to the amp. Pos to pos, neg to neg. You should have a 1.3 Ohms total resistance.
I meant I want to run these series parallel and run it bridged between two channels. Did you tell me to wire it as if I was running two channels? That guy I bought it from had them wired separately one wired to the box terminals and the other with a cord coming out the side. I want to wire them both back to the factory box terminals and plug that hole on the side
Can you clarify the question? "Bridged on two channels" is a curveball.
Are you running your amp in 2-channel mode, or do you have a stereo amp you are bridging to run mono?
Also, what do you mean you have two subs and one is 4ohm and the other is 2ohm? Aren't the Kicker DVCs a dual voice coil sub with each voice coil at 4 ohms to start?
I can diagram what you'll need to do it you can clarify the info.
They are the same brand and model. Just different ohms one is 4 the other is 2
it doesn't work that way if you are running them as a "single" sub per amp channel.
Each v/c is 4 ohms. If you parallel wire the v/c on the sub, you get 2 ohms; if you series wire it you get 8 ohms.
What amp do you have, and how do you want to run the amp?
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Zachhunter
Zachhunter
Florida
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
