Gabriel7960
Car: 2019 Camry XSE 8” display, Non-JBL
Speakers: Front - JBL Club 602CTP.
Rear - JBL Club 620F
Amp: Infinity Reference 3004A
Subs: Skar SDR 2x10
Amp: Skar 1500 watt mono
I have a white noise/hiss coming from the tweeters of my component system. The noise is there when the radio turns on. If off, it goes away. Unplugging RCA’s to amp removes the noise. No my gain is not high at all.
What I’ve done:
Changed RCA’s (3 different kinds, all three twisted, one shielded)
Moved rca from any power wire.
Wired amp outputs directly to crossovers (not using factory wiring)
Tried ground loop isolators.
Installed LC6i LOC
Used different ground switches on LOC
I am going to check the grounds soon with a multimeter, but they seem to be perfectly fine. Audio shop says they are fine. This noise only comes out of tweeters. I also notice sometimes that the left tweeter (could be both) cuts in and out. There is also a rhythmic ticking or clicking that plays sometimes when I play music. If a song has higher pitched tones, the noise becomes more apparent.
I don’t believe it could be a ground issue because it is only coming out of the tweeters, not the woofers or coax in the rear.
Subs: Skar SDR 2x10
What I’ve done:
Installed LC6i LOC
