Each cell can actually hold 2.9v. You will be good up to 14.5. Are you running a 5s bank? Have you ever ran one? I'm running one 40ah 5s bank of XS Power in my truck.
You do you I will not run a 5s over 14v. Even at 2.9 a cell that would still be on the ragged edge of failure for lto. And their are several instances of the titan8 battery failing when above 14v
Xspowers uses Toshiba scibs
Toshiba doesn't post many specs but indirect you can find the 10ah has the same nominal and max cell voltages
20ah
