Sundown subs
LMJexploder
So I know Its not a good idea to mix different size or brand subs in the same enclosure, but would it be a bad idea to run 2 zv5 12"s and 2 zv6 12"s in the same enclosure. I would be running 2 salt 6ks, 1 for each pair of subs. I already have2 zv5s and everywhere I look there out of stock or discontinued. Thats the reason I ask about this setup.
Ok that's all great but the zv5 12 d1 is out of stock according to the website
I could be wrong but will that not create an unequal positive force inside the chamber? If they were all sperate chambers I don't see a problem. But if their married I personally wouldn't do it.
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
Sorry for the double post, I meant to post this in the enclosure section. Mods can delete if needed.
364
LMJexploder
LMJexploder
Seattle WA
hispls
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
