CDT 2 ohm 6x9 carbon fiber
I like and am a freak for CDT speakers the majority of the time ( Dont care too much for the CL series, but were within my budget at the time) and Image Dynamics,DD, Infinity Kappas, and Polk DB and MM series, I really like also. I am and have been looking at the CDT 2" mids/Tweets and some some Mmatts Tweeters(been eyeballing these for a while now)
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=194214251967
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=110807408392
These play from 30htz-3500. Little pricey maybe.. But Carbon fiber cone.and should last
https://www.woofersetc.com/p-10163-es-0690-gold-cdt-audio-6x9-2-way-extended-mid-bass-speakers.html
I looked at these but i have a 4 channel amp that puts its power out at 2 ohms. I could only feed them with around 80 watts. I’m really limited with my choices running this amp. I could get a tiny 2 channel for my tweeters and bridge the 4 channel and get 200 rms x 2 @ 4 ohms. That’s my next step if these 6x9s aren’t to my liking. I’m playing them free air a little now and they seem nice. Kinda surprised that a 6x9 with no tweeter can play up to 7000 hz but it does. These should keep me happy for a few months at least. Right now I’m running dual 4 ohm woofers in the 6x9 spot and they can’t even play up to 7000 hz. They drop off at around 5500 hz. Probably doesn’t matter really, since I will be crossed over at between 3000-4500.
I’m replacing these 4 inch woofers, so I’m expecting a noticeable jump in the midbass under 500hz or so. I should also be able to put the stock speaker cover back on since the shallow mount on these CDT will allow it to fit. I’m still putting a 3/4 inch MDF ring in to mount the 6x9 to. These 4 inch woofers have a 1.5 inch spacer.
The Infinity set is a 2.5 ohm config. They can be had on Amazon for $140 (used like new). I don’t use the tweeter though as this set is meant for a 3 way as the tweeter has to be crossed at 4khz and up.
I’m using a Dayton audio silk dome tweeter with these. 2500-20,000 hz 40 watts rms. I have them crossed over at 4000 right now and they sound pretty nice.
I ended up using SB Acoustics and have them crossed at 2000ish. I love Dayton so I would mind trying some of their tweeters.
I tried the Dayton titanium dome tweeters first, and they were ok, but not in a car. In a home stereo where your further away from the tweeter they’d be fine. Just too harsh in vehicle IMO.
I can see that. I’m partial to silk dome in cars. What model are the Dayton’s?
SlugButter
CarAudio.com VIP
SlugButter
arizona
Buck
