Sixth Order for Standard Cab Chevy
  • 2
Bobbytwonames
Trigger Man!
13,024
1,810
Vegas
We built this last night. Sixth order blow through for an 03' Chevy standard cab. Tuning was 44 hz. and 22 hz. It was built for two Skar ZVX 15's. on 7K. He's going to Rhino line it and build a tonneau cover.
That box looks so small. That rear port looks extremly tiny for 7k, even at 22 hz. Sometimes it's just gotta be that way. That can't be more than 30 in^2 or so on that rear port.
I'm not sure how many cubes the rear is. I know the ratio is a little under 2:1.
I bet it's around 6-7 cubes or so. I doubt it's any bigger than 7.5 or so. Front size can vary widely, just as long as that front port is big enough haha. Are the motors in the back or front? That changes sizes a bit.
I didn't get a pic of the front port, but it seemed pretty big. I'll find out in a little bit. The guy wanted to be able to do hair tricks.
I'm just always studying. 6ths are so versatile, it's fun to see the results of them. On these high powered builds, they are just extremely useful for many reasons. I'd love to see a video of this whenever it's playing!
Me too. Hey those SIA amps from Sundown blow away the SFB's. I put an SIA3500 in my truck yesterday and it's a huge difference. Louder, cleaner, and lower.
Amp stats matter haha, just like subs stats do. I'd spend more on my amps and get a cheaper sub. A sub is nothing without an amp that actually makes the sub move to the waveform.
If you're playing lows, you'll be louder with a higher quality amp. I've quite literally tested this. People don't understand how important dampening factor is, in my opinion. My ED amps were fairly large and heavy for their ratings, but there's a reason for that. Wattage is far from the only rating of an amp. Some of the cheaper, higher wattage amps basically just throw the subs up and down in a very poorly controlled way. That causes distortion, and distortion causes pressure issues. Best bass is when the sub is fluid and always moving exactly to the shape of the waveform. That's why box sizes and port sizes matter, too. The woofer is always changing impedance and that ties into the voltage production of the woofer, and some amps just can't handle too much excursion, because they can't control the sub well.
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
328
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
747
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
876
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
Bobbytwonames
slater
    May 2, 2024
slater
    May 2, 2024
