Pops New System
619Thump
need help building box, Pops just bought 2 sundown sa classic 10’s and a sfb 1500, hes trying to make it kind of stealth so his max dimensions are 32W x 14H x 12D, i was hoping to build a ported but if it has to be sealed than it is what it is
need help building box dimensions, Pops just bought 2 sundown sa classic 10’s and a sfb 1500, hes trying to make it kind of stealth so his max dimensions are 32W x 14H x 12D, i was hoping to build a ported but if it has to be sealed than it is what it is
this box is around 2.4 cu after all displacements which seems good seeing that sundown recommends 1 - 1.25 cu but i dont know about the port area or net internal volume
That box is 2.31 cubes internally if you are using ¾" material. After sub and port displacement it might be pretty tight for a pair of 10's. You will probably be around 2.1 cubes after sub displacement. Then, you still have to subtract the port.
so would you just recommend to do sealed box?
371
19
729
793
619Thump
619Thump
San Diego
Bobbytwonames
    May 11, 2024
RedRyder18
    May 11, 2024
