Buck Box Designs - New Picture Log
Theorizing if this would work for a home audio t-line setup for a 15. This one is modeled for a Fi IB3 15, tuned for Fs.
27144
Also is it just me or for something like this one that they offer a 2.75" voice coil seems small?
I've literally had the exact same thought. They do have CCA coils which can help with heat. I'd imagine that they would have a good bit of cooling to help with the heat. I guess 2.75 isn't that much smaller than a 3". I can't imagine a sub with a coil that size having any more power handling than that. The length of the coil matters a ton too, when it comes to power handling. There's a big difference between something like an 8 layer coil vs. a long 4 layer coil.
Deaf Bonce should give more detailed t/s parameters. I need Mms, Qms, Qes at least. I would be hesitant to buy a woofer with that few of t/s parameters personally, even though they really seem like powerful woofers.
Who does Skar's t/s parameters? Something is just horrifically off. Something there is like double or half of what it's supposed to be. Idk if they took these t/s parameters with zero break in time, idk. I highly doubt that woofer's Fs is 51 hz. Rms is pretty high too and Cms is pretty low too. It may be a stiff sub but I really doubt it's THAT stiff with a 1500w rating.
Buck
little alien on campus
Buck
Inside of a pyramid
Original wis
