Is 38hz for a box decent?
@hispls , they have competitions where you get more points the lower of the frequency you play. I just tuned a box to about 23-24 hz (by request). Tuning to the mid-high 30's can be peaky. It just depends on what the person wants. Idc where people want their boxes tuned, I just do what they want based off music response. Also, very rarely do I tune a box low and have people not like it. Low as in like 32 hz or so. I find a lot of people are not aware how much low end response that they are missing out on. It just depends on the user.
A large ported enclosure is what I would use for spl/sq. Tuned low. This will give you a flat response and higher output than sealed. Figure out the largest enclosure you can fit, then do the port so it is tuned low. I am tuned at 28hz. My box is over 3 cubes. Slot port boxes arent too hard to build.
Here is my box's curve.
image hosting website
Most enjoyable tuning I had was 38-40hz. My preference is rock & old school rap while hitting the occasional Spl number. And that tuning was what my cabin liked.
The lower tunings are all well and good but slowed/rebassed crap gets old. I'm not a fan of modern rap either.
Hell... Im cruising around with a deck powering front door cheapo coax atm.
Different folks = different goals I guess.
Maybe someday I'll throw this Blaupunkt sub in there, but im not really missing the lows yet.
in a free air environment you would get a sharp drop off at 38hz in a ported box at 38 hz, but with cabin gain in a vehicle, you likely will have a hump in the low end frequencies anyway. I had an Orion sub back in the day that I had ported at 40 hz, but it played lower than that. For some people, a flat signal AFTER cabin gain is what is considered “SQ”, which is easier with a sealed setup. Ported setups have a nice little hump in the low end that some people actually prefer. I’m a fan of ported setups myself, but I like to find subs to run small and tune low to get a little flatter response after the cabin does its work on the lower frequencies.
Q Power Deluxes. Tune them at 32-34 hz.
You could tune them higher but with a cheaper sub, it's typically not going to play well under tuning by a whole lot. Those subs are cheap but they are well designed. 4 Q power 12's on 2000 watts can hit a 145. 4 15's on 2000w can hit about 147, we did this a while ago. 12's were in a blazer, 15's were in a 2 door cherokee. They actually sound pretty decent for their price.
I only have an amp that pushes around 500w rms @4ohm that is the llowest impedance bridged
120
419
398
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
Go get some shitty wood or cardboard or something and figure out what the max is, play around with different dimensions to see what the max cubic...
23
883
Coreybruner
Coreybruner
Sacramento
Buck
    Apr 27, 2024
    Apr 27, 2024
