I currently have a Kicker CompC 10inch SVC subwoofer and a Kicker CX 400 Mono Amp. I was wanting to hook up another 10 inch Kicker CompC sub.
Right now it runs 150 watts @ 4ohms to the 1 sub, if I wire in parallel it says the amp will put out 300 watts x 1 @ 2 ohms. Does this mean each sub will run at 300 watts? Or will it just split the power equally, as in 150 watts to each sub?
The subs are rated for 300 watts rms.
They make the Kicker CX 800 Mono amp that says it can run 600 watts x 1 @2ohms, would this be the better option amplifier to get the most out of the 2 subwoofers?
Also I have a 65amp fuse for the power cable, would I need to upgrade that if I got the Kicker CX 800 mono amp?
Thanks.
Thanks.
