Need advice on my audio system setup, not getting much power from my sub
17tusol4
Oregon
Good afternoon, I have a earthquake subzero 10 inch 1,500 watt sub with a 1,600 watt kicker amp connected to it and I am running a 1,400 watt cable wire, I am not getting much power out of the sub, not sure if it's because of the low wire wattage or if I need to get a stronger amp, could you give me some advice of what the problem could be and how I can fix it or make it better, thanks
Running a 4 gauge copper cable from car battery to a kicker cxa800.1 amp
And from the amp I'm running a 12 gauge wire to the subwoofer both are aluminum wires
Looks like that amp puts out 600 watts at 2 ohms which is what your sub can be configured for. I would get a higher power amp. You can run 1200 watts or so on your 4 gauge.
3,000 will require an electrical upgrade and much bigger wire. You could get something like a 1500-1750 watt amp to have a little headroom. I bet you can push that sub a little harder than RMS. Put some power on that baby.
Could I get a 2500 watt amp if I get a capacitor if so what kind do you recommend?
I agree with CRX. Everything seems perfectly matched so best step is a ported box.
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
269
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
691
Try removing all the signal from the amp, turn the gains up and down, see it is present. If it is, then the amp is the issue,if not, then it is...
991
17tusol4
17tusol4
Oregon
LsGuy
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
