Sub Suggestion
  • 6
619Thump
Number of Subs : 2
Size preferred : 15
Budget : anywhere from $500 - $700
Power to be used : either a D4S JP23 (2k-2.3k rms at 1 ohm) or a sundown sfb 3k depending on sub rms ratings
Space Available : 47L x 18D x 17H
Goals : loud and with a good mix of spl and sq
Listening habits : Rap, corridos, old school r&b
Preferred brands : doesnt matter as long as they bump
I know i have to upgrade alternator, batteries, etc, will get everything at the same time so i could install it all together
In my opinion, and opinions will always differ from person to person, I love the mix of volume and sound quality you get with FI subs. That's my 2 cents
FI has been saying up to 45 days due to covid before they get built last time I checked on anything at their website. Best to ask them via email or facebook as they usually get right back to you.
"Due to COVID-19 all orders can have upto 45 business days lead time"
Too Bad they don't make the 12" in a Dual 4ohm otherwise I would seriously think about them over the SSA Icons I have been looking at as the RMS is perfect on the XV3 Series.
Either way you can not go wrong with either the SSA Subwoofer, FI or DD or even DC.
Talk to @Buck about a box and the results he has gotten out of each of those subwoofers as he has done a few hundred box designs over the years.
yea these subs are the ones i was looking at, they just caught my eye with the price range, rms rating and the look overall, but if i buy it i dont wanna wait almost 2 months for it
He is only going to get maybe 3 cubes per sub in a ported enclosure with his available space. Probably less after sub , port and bracing displacement. These are all great subs, but I would think that most of these need 4 cubes for each sub. Can you raise the enclosure size a bit? Or are you stuck at the measurements you originally posted?
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
482
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
339
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
483
619Thump
619Thump
San Diego
Marve_Lous
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
