Sealed box but how big?
  • 5
Always better to build your own box then build some fabricated junk that will fall apart over time. Not too mention the sound differences. If anything find out how much room you have, what the subwoofers call for in a ported box and go from there. Or find a box designer and tell them what you have for subwoofers and send them a picture of the area you have to work with and they can design a box that will work with said subwoofers, space and type of music you listen to.
generally the manufacturer specs are good for box size. i agree with dude above, build you own box. it's not that hard. just slap some paint on it or something. you can do a low price box and have great sound. might i recommend doing ported to the side. you also should include what type of music and bass you want to play when considering an enclosure.
been a minute
So I listen to hip-hop/rap music. I’m trying to fit it in my 2003 single cab Silverado so I don’t have much space in the back. I Have read that with ported subs are tuned. Is that true? If I built one could I make it like this in a wedge form?
you can make a box whatever shape really, it just has to be enough room for sub depth and enough port length and area and enough net cubic feet for the woofer
What he said... Any damping of over 80 is fine, 200 is really good, so 1000 is like my 80lb home audio amp! Unless you are using certified Hi-res...
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
Rayher12
Rayher12
Fresno, Ca
Buck
    Apr 28, 2024
    Apr 28, 2024
