Amp Recommendations
Rdangeau
Arkansas
Have a kicker sol baric 15“ 2ohm sub. Currently have a hiphonics 2400 amp connected. I know it’s a cheap model and I don’t feel as if I’m getting all I should with that sub. what would be a good recommendation? dont want to break the bank...$500 or less?
Picture of your box along with letting us know what head unit you have and how your gains are set
I had a 15" L7 on a ZX1500.1 and it was a good match. Mine was dual four ohm and the same was only two ohm stable though.
23966
Stock head unit with pac amp pro ap4-fd21
So the stock head unit cutting off bass signals from built in high pass crossovers is definitely holding you back like it'll reduce the performance of any setup you have by 70% kind of bad. The box is absolute trash as well, dont expect any kind of performance out of that box at all. So those are the key issues you need to address. You subs and amps are fine
Dayton dsp and bluetooth dongle costs 180 or a kicker sum8 works too.
A custom ported box (can copy shredder's design) would cost you 300. There thats how you should spend your 500.
Next thing on your list afterwards is upgrading electricals
It sets in the back seat of 2013 Ford F-150 supercrew. any suggestions? i guess I have too large sub for application. previously it was in larger box which was located in trunk of car
So get rid of amp pro? how do I connect amp?
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
392
Kicker still makes some really great amplifiers. They have been in Business for years. I still have some old amps left that still work very well...
An amplifier to be considered, maybe even the 2k? https://www.ctsounds.com/collections/ct-series-amplifiers/products/ct-3200-1d
893
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
Rdangeau
Rdangeau
Arkansas
SlugButter
    May 4, 2024
slater
    May 2, 2024
