Tips for running power wires under vehicle
jt4x4
CarAudio.com Exclusive
299
81
ND
I'm not interested in opinions about whether or not to run power wires outside of the cab. I've already decided on that. I'm looking for pointers from people who prefer that route (holyfuck I hate puns....). I ran a 4g power in the frame of my 4x4, but that has a c-channel frame, whereas my Explorer has a fully boxed frame.
What I'm looking for is tips to get from the battery out of the engine compartment; do you remove fender liner and go above that?
What kind of fasteners have worked well? One-hole zipties and self-tappers? Stick-on cable tie mounts? Any others?
What works well for fusing when the wire disappears from sight and accessibility as quickly as possible?
What kind of loom or protection do you use? Or lube... had to get in front of that one... wow this is never-ending... ok stop!
I will obviously avoid heat, moving parts, and sharp edges.
Thanks in advance.
- Joe
I've never seen this done on anything other than trailered competition vehicles. Definitely fuse before the wire goes out of sight and double up from whatever you think you need to secure it. I suppose if you really cared to be extra safe you could get some of that flexible conduit (like wire loom but steel) to run the wire through and that should keep you safe from almost anything.
How did you fish through boxed frame? Did you drill holes to get into it?
On my Lightning the frame wasn't boxed so I just ran it down the C channel. But on boxed frames they still have access holes. Just use rubber grommets to make sure it doesn't rub through the wire jacket.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
jt4x4
jt4x4
ND
SlugButter
    May 4, 2024
slater
    May 2, 2024
