Do i have enough electrical to support 5k and a rockford 600.4
  • 2
sounds_explicit
Atm i have a taramps bass 3k.. im looking into selling that as i got a few offers and i was interested in a bass 5k.. i have plat agm under hood, northstar agm 31 pro in trunk. Voltage regulator i charge at 14.9 volts, and a brand x 350 amp alt. Im thinking i may need to add another batt? I got about 160ish or little more of ah...
You can run Headway lithiums with AGM. LTO you can not.
Ahh. Well so I would need at least what 5 or 6 of those cells ? Of the headway ones? I want to eventually get into lithium. I just have not done hardly any research on them
And I thought they were thousands of dollars. 🤦🏼‍♂️ I may try to sell this agm who knows. I've got a evo x that's built for speed that I want to eventually do door panels with 6.5 and 8's so I may go lithium in that so I dont have 100 lbs of agm in the trunk. Guess I'll have to so some research .
You could do 6 Yinlong LTO cells and be fine. 40ah of LTO can support 5k. Save alot of weight and space. Headway Lifepo4 you would need around 40-56ah or 20-28 cells. One bank of 4 Headway cells can support around 800 watts.
Ew on the headway. I looked them up 80 buck a cell I'm good on 20 cells at that price LOL
So if I got rid of the agm and did yinlong matches with my 350 alt i could easily support 6-7k? I plan on adding another rockford 400.4 soon probably as well
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
sounds_explicit
sounds_explicit
cleveland ohio
sounds_explicit
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
