Need help wiring blind spot camera to Blaupunkt radio
  • 2
afbryant
Hello everyone, I recently bought a cheap Blaupunkt radio mainly because I wanted to install cameras into an older truck. The radio has rca ports for two cameras. I have the rear camera working good but I cannot figure out how to wire up the camera that I am going to use at the mirror.
Can someone please lead me in the right direction to get started. I was planning on triggering it with the turn signal. I cannot find much on the web for side camers. There is tuns of info for wiring reverse cameras.
Maybe someone can give me a link to some detailed information. I am just getting nothing at all. Am I going to need a separate module or something for another camera?
It is a Blaupunkt Berlin622 radio. The harness had a dedicated wire for the reverse camera but not the front/side camera
Could not find a manual for your specific unit, but a similar one has the pink wire as remote for the rear camera while the pink with black for the front camera.
This one has a orange/black wire for the rear camera but it has no wire for a front camera. Is there "supposed" to be a wire for the front camera? There certainly is a RCA port for it.
It would make sense for there to be one since other models have it. Download a manual for a similar model and compare it's harness to yours. If all is alike, you may be missing a wire. You may even be able to use another model's harness. Also check your settings, you may have a model that switches front to rear camera via on screen button.
I took the radio out of another car and it has dedicated wires for both front and rear cameras. So , does anyone know if there is another way to install it without that wire?
That wire is the activator, so without it no. Is there a wire that is not being used in the harness? Something like antennae remote. If yes, then you can painstakingly remove it and insert in the front camera slot. I have done this before, so you must flag it, very important.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
457
afbryant
afbryant
    Apr 28, 2024
    Apr 28, 2024
