Sub and Amp suggestions
Nico2Wavy
13
i got an 04 suburban, thinking of putting 2 15’s. Can yall help and give me more suggestions for subs and an amplifier (or 2 if i need it). Trying to be on a $1k budget for the subs and amp only. Also trying to be heard from a far distance.
Big question is can you build your own box? I'm pretty happy with my setup, but it required some carpentry. I have an orion XTR2500.1dz and two deaf bonce apocalypse sa2615's. The subs and amp put me back around $800. With wires and box materials, I've probably spent around a thousand.
Here's a video of my subs:
- Build your own box (60$ in material plus a few buck for someone to make you a design)
- Couple of these: ($390)
- this amp wont crush electrical ($410)
Buy a two channel rca (20$) - nvx v series are good quality
30 ft or so of 2/0 and some lugs for amp power wore and big 3 (110$)
Small spool of 10 guage speaker wire (20$)
3-4. 250 amp anl fuses and holders (30$)
Assumptions made
-You have an agm under the hood
-You don’t plan on pounding your system with the car off
-your headunit/source signal is strong and clean(not factory)
are they good on sql? im not really going for spl results jus trying to be loud and have good clean sound 😂
Nico2Wavy
Nico2Wavy
Nico2Wavy
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
