3 ohm speakers
Sundown has a 5 channel the 1100.5 that does 75x4 @ 4 ohms and 800 rms at 1 ohm on subwoofer channel.
They are also going to be dropping their full bridge 5 channel very soon. The SBF1800.5
Could always go Taramps with a DS800x4 and MD1200.1
For 6.5" component set I would go with NVX VSP or Morel Maximos
I just thought he was stuck with that amp. The SA-12 with that amp would be a nice set-up in that car. His electrical should be fine with the Taramps set-up as well.
Popwars dual amp recommendation is solid. A lot of power in two solidly efficient and small footprint full bridge amps. Then there’s some solid budget $150-200 12’s that can take 1000 watts. You could even do a 1000 watt 10” In a ported enclosure giving up less space. 2.5 cubes vs 1.5 cubes
I've never heard of those amps and just checked them out I'm going to get them holy crap they are good and very small. Thank you Popwar.
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
201
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
855
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
BenderD
BenderD
Coos bay
BenderD
slater
    May 2, 2024
slater
    May 2, 2024
