Taramps MD or Bass
Whats the difference between these amps? The MD is rated for the same power at lower voltage compared to the bass line. And the MD is cheaper.
What makes the bass line more expensive? Is it better for lower impedances, running below rated impedance? I see a lot of recommendations for taramps around here, anyone know? Is one more efficient than the other.
Better is always dependent on application. Like I said unless you are wiring under 1 ohm I would run an MD. There is an MD12k .5 ohm version though.
The DSP line will always be my favorite from Taramps but unfortunately they did away with the 3000, 2500, and only producing the 1600 now.
Now, I feel like I cheaped out by getting the MD line when the Bass line was the better choice.
T Reds 19
T Reds 19
Akron, OH
Psi_optima12
