I just got Baby II switched over to FULL ACTIVE EQ!!
You just need thick skin. Ive learned some stuff here.
I was first on the Internet in Computer Engineering school 1989-1995 almost before there was a WWW and Usenet Newsgroups and one of my fave newsgroups was Alt.Tasteless just after a huge flamewar with rec.pets.cats! So I learned to have a VERY thick skin!
John Kuthe...
Not everyone obsesses about some newcomer's lack of experience with modern car audio equipment. I hacked together a pretty good stealth audio system for Baby II despite.
And I JUST had Custom Sounds make use of the existent second set of 75W amp output wires run to the front 5.25" Phd speakers, for their separate tweeters as I just had their tech switch my system over to full active EQ and it sound even MORE FANTASTIC! And now my sub is even LOUDER compared to the other drivers!
And I've only listened to my '90's CD in it! Gotta put some Miles Davis on it, Jack Johnson sessions! Think I will RIGHT NOW!
John Kuthe...
And I JUST went out and listened to a few of the Jack Johnson sessions CD, also a Phoebe Legere (sp?) CD and one from the Crash Street Kids too! WOW!!!! Active EQ IS everything it's cracked UP TO BE TOO! :) I'm sorry now I hardly ever DRIVE Baby II as she's a stinking GAS BURNER and I drive my 100% electric Nissan Leaf which used ZERO gasoline!
John Kuthe...
[QUOTE="JohnKuthe, post: 8689053, member: I'm sorry now I hardly ever DRIVE Baby II as she's a stinking GAS BURNER and I drive my 100% electric Nissan Leaf which used ZERO gasoline!
John Kuthe...
[/QUOTE]
It "uses" ZERO gasoline, not "used." If you said drove then used would be correct. Mix in a English class. Make Hunter S. Thompson happy flower child.
John Kuthe...
Is that you in the pic? Holy shit. The retardism commences.
It's actually actively crossed over, eq'ed, and time aligned. So stop calling it active eq on purpose like a jackass to piss people off hippy
Whatever it is, WORKS! Yes I know about time alignment, as there is no longer the identifiable "sweet spot" like before when I lean over and put my head in the middle of the sound stage, it's time aligned to put the "sweet spot" where the driver's head is!
John Kuthe...
JohnKuthe
JohnKuthe
Missouri
