2 woofers 1 tweeter on a crossover??
Taylor xDx
Oregon
Hey all, I’m new to audio. I want to have (2) 5.25 4 ohm speakers in both front doors and one tweeter in dashboard. Can i do this? Power is coming from a rockford 1000 watt 5 channel. The rear channels are powering (2) 4x10 in rear deck. Very appreciative of any feedback.
Taylor
Taylor
(Edit) two tweeters in dash actually. So itd be two 5.25 woofers and one tweeter per front channel on amp. Thanx again.
So I guess just run the 2 5-1/4 woofers out of the output on the crossover in parallel?? Hopefully that won’t fry the crossover or mess with the frequency.
Looks like ill be running a focal 130as component in front opening off front amp channel and ill run the 2nd 5.25 opening parallel with the rear deck 4x10s off the amps rear channel. Where can you find non coaxial 5.25 speakers separate without having to buy crossover and tweeter?
If you have passive crossovers for a 4ohm woofer and a 4ohm tweeter you can use (2) 8ohm 5.25's in parallel to create a 4ohm load and connect that to the woofer output of the passive xover. Then connect a 4ohm tweet and you're all set.
Oh sweet! That’s what I wanted to hear! Thank u very much.
As I was reading and read the 4 x 10... I said, is it a Buick Regal to myself lol. Hey, I think Qlogic still has kick panel pods for the Regal. Awesome car by the way.
Thank you! I made the mistake of mounting 2 5.25 coax in each door and while its loud, it doesn’t sound as good as I’d like.
I think door panels are available too for the GN. Those kick panel pods though... done right with the right speakers and that thing will be clean and loud.
OH!!!! and these!!!
OH!!!! and these!!!
For sure! I got the 6x9 adapters but found I’d have to remove my trunk torsion bars to install them. Almost did it but decided against it.
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Thank you for your advice, everyone. I feel much more confident going forward. You guys are great (y)
17
This is an easier one. They're not authorized on most brands they sell. I've witnessed them using heat guns to peel off the serial number sticker...
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
Taylor xDx
Taylor xDx
Oregon
Taylor xDx
    May 8, 2024
    May 8, 2024
