*PICS* My Active DIY Component Setup
ngsm13
BSEE
41,527
6
Cincinnati, OH
WOOT!!
Everything is here... (all clickable thumbnails)
What it is:
RE XXX6.5's
Vifa 1" Neodymium Textile Tweeters
Pheonix Gold Tantrum 400.4 (Might consider upgrading to PG Titanium 500.4, what do you guys think?)
Coustic XM6 3 Way Crossover
Going into...
http://forums.caraudio.com/vb/showthread.php?t=94516
Also, check out my new toy //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
http://forums.caraudio.com/vb/showthread.php?p=877372#post877372
WOOOOOOT!
NG
Vey nice! Congrats. I'm going active too. I can't wait for all my stuff to get here.
BTW, do you think it is really worth it having that coustic x over? I am going to try using the amp x overs and my h/u crossovers at first.
I think it is 110% worth it...no way I'd use internal processing...shy of my Eclipse 8053 when I had it.
Plus the coustic is like $50-80 on ebay //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
NG
I just might be getting an 8454 in the near future, so I'll have to wait and see on that. Thanks for the tip though.
Enough of this thread jacking. Now go install those beasts and let us know how it sounds.
Hopefully we'll get them installed in something just to get an idea of what he's dealing with.... while we're not sanding the **** outta his pods...
Heres the crossover im using.
idxm1os.th.jpg'%20alt='idxm1os.th.jpg'>
WOOT!!
What it is:
RE XXX6.5's
Going into...
WOOOOOOT!
NG
wow, I ran a similar setup!
Tweeters and everything except for I used the active crossover in my headunit. I liked the Vifa tweeters but just did not have the sound that I wanted. I am still looking for a good pair or tweeters to match up with my XXX mids that can take the power! Though Im sure you will like what you get from that setup, hang in there. It will take you a wile to dial in what sounds good for you. I will let you know what I had when I was using that setup:
Sub = down-85hz at 12db slope
mid = 85hz-5k at 18db slope
tweet = 5k- up at 18db slope
or:
mid = 85hz-4.3k at 18db slope
tweet = 4.3k- up at 24db slope
That should give you an Idea to start with and you can go from there.... I tell ya I did change it alot and tryed alot of combo's. I think you should start at 5k on the tweeter and work down if you can wile increasing the crossover slope to 24db to even 36db if you can, if you can get it low enough. The XXX mids can play all the way up and had no problem at 5k and higher if you need to. But its all up to you how you like it to sound. I wish I could do it over again because It was so fun setting it up the first time! I wish I can find a tweeter I like though, its hard to find a place that will only let me listen to a tweeter for my stage, instead they want me to buy the whole set...
Good luck, and have fun!!
P.S. Nice dead/hot pixels you have there!
Thanks for the advice Tedro, and as for the digicam...it's a hand-me-down...I take what I get in that area //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
ill throw a thread up for MY DIY active setup.
i wish the kodas were SVC2 tho //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
look good noah //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains...
5
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
297
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
859
ngsm13
BSEE
ngsm13
Cincinnati, OH
eric77
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
