Speaker help with 2019 ram
  • 3
Jamie clevenger
CarAudio.com Newbie
I bought a new 2019 ram 1500 big horn. It should have 3.5” in the dash and 6x9 in all doors. It’s the base stereo. I’m going to upgrade the speakers to something better but what I want to know is the speakers in the dash have 8ohm stamped on them and I haven’t looked at the 6x9s yet but I was told they are 2 ohm. Should the replacements match those ohms? It will be hard to find 2 ohm x9s. I want them to sound good which I have found that normally doesn’t happen when I change factory speakers for some reason. Normally they have no bass response. Any help would be appreciated.
Wow they still use 3.5"s? That's crazy, my 85 MR2 has 3.5s in the dash and they **** all the ass. But upgrading the speakers without upgrading anything else will most likely only lead to very disappointing results. You'll need an amp and to deaden the doors for real upgrades.
Doing the doors, I was already planning on. I’m not to sure how to do an amp with the radio that’s in the truck now. It’s the 8.4” radio and I don’t plan to remove it. I used an inline alpine amp in my last truck but I didn’t have all the features this truck has
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
6
603
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
Sorry, didn’t watch the video the first time for some reason. Supper helpful video. I will try that. I guess the RMS rating is oversimplified...
7
Jamie clevenger
CarAudio.com Newbie
Jamie clevenger
nauc
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
