Cheap power
mwilder95
Looking for something to put on my sundown audio z18 v.4 it’s a dual 2ohm. My budget is $260. I’m looking at the skar audio rp 2000.1d and the wolfram c2400.1. Any other suggestions? Which is my better option
For a few freaks it will be. Big 3 is done I’m either going to get a bigger alt or a big battery up front. Both will be done when I can afford it. I can’t do it all at one lick
A bigger battery or even an extra battery is a fix for a marginally underpowered electrical system.
I'm going to say that amplifier will pull in the ballpark of 200 amps conservatively.
If you want to learn an expensive lesson, run an amplifier like this on a stock electrical system.
Big three will help, but in the grand scheme of things its not going to make a huge difference considering how underpowered your electrical will be.
I'm aware this isn't the question you asked, but I'm hoping that I can save you some money.
I would personally set the gain via DMM to match a realistic output for your electrical.
Weeks not freaks 😂
freaks for weeks!!!
he is planning on upgrading the electrical so it doesnt really matter if he gets a huge amp right now and just keeps the gain down until his electrical can support the draw to maintain voltage.
OP, get the gear you plan on running and install it on the weak electrical, just dont beat on it until your electrical can handle it. The expensive lesson he is referring to is smoking your amp by dropping below 12 volts at the amp rack. Increasing amperage draw decreases voltage but if your gain is set to where the amp is only pulling a reasonable amount of amperes until your electrical is up to the task, youll be fine
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
Starting from scratch don't have an amp yet gonna wait till I make a decision on which subs right now I'm just trying to settle on which subs I'm...
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
509
mwilder95
mwilder95
youdoofus
    Jun 3, 2024
