Subs and amp randomly quit
  • 4
Joestephan
So I recently had subs and amp installed and everything was working fine when it just went silent. The music wasn’t loud so I know it wasn’t blown and then the next day they worked again for about a hour and then quit again. Any clue what’s wrong?
Check all your supply wiring and ground wiring and remote wire.check all your RCA connections..get your alternator bench tested..get your battery bench tested.Check all your fuses and block connections.Pull your sub or subs and check the connections..Check your coils on each sub unwired from the amplifier and independently with a DMM. That would be a start for you.
List you amp, subs, vehicle, and electrical upgrades. Probably clipping it to hell and the amp is shutting down to keep from blowing. Once it cools off it works again.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
931
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Joestephan
Joestephan
Slo_Ride
    May 10, 2024
3toneEYZ
    May 10, 2024
