Went to HISPL's place and did some NS1 vs Shocker 4kw testing with his wall - *vids*
CRXBMPN
Moe Bass
9,091
Maine
Backed my rig up to his, swapped some speaker wire out, and we did some head to head testing of my Sundown NS1 @ .7 ohm vs his mammoth Shocker 4kw @ .7 ohm. The subs were a wall of Shocker Neo 15's, peaking at 43hz.
Final results - Sundown NS1 - 154.20, Shocker 4kw 155.57. Thorough @$$ whipping!!!!
My Eclipse Ti 12's next to a Shocker Sig 12
Corolla with a Shocker Sig Neo 12
My NS1 - ended up getting it .22db higher than the # on the screen at the end
Looks like the same pcb?
Jon said it was the same board as something else, I don't remember what. I think the badging on one of the spares I got for him to get repaired said Helion 9000.1 or something. He mentioned a 10k, though. It sure put a hurting on my NS1. Good thing I have two to combat that problem >:-]
Yes, it's very secluded out here. Can do pretty much anything I want without being bothered.
Nice pics, Jason. I should have those 12's repaired this weekend at some point but you'll need to bring your meter if you want to do any of that, I'm loaning mine out for a couple weeks
OK. Let me find your DATS machine and get that back to you. I can pick those subs up and then painstakingly put them back in the van for one final test. Perhaps we can back the vehicles up again and do another NS1 vs 4kw, Minivan No Wall edition down the road after I install them when I have time.
I also want to take my front seats out for some baseline testing. I know I can swing nuts at a 155.3 with my mid seats out and box pushed up pretty far on the riser. The only issue with putting both NS1's in is my voltage is shitola, hopefully I can get those two D3100's from Zak and integrate them easily. I just need wire, I think.
Nice.
That Sig is unholy, what big mofo.
Looks like a couple banks of transistors missing in that beast. Undergoing repairs? Or beefing it up?
Nice.
I also live the same 20 min distance from TheAmpLab boys, so I'll be shuttling the amps up to them for a going over for HISPLS. I went to high school with one of them, so it's always nice to catch up anyway.
Those are 2 amps I bought this winter. Same board as my Shocker "4K" but different heatsink.
Yeah, if I'm not trying to cook sugar the seats come out pretty quick and we could test my amp into the 3 12's in yours.... we also need to get your seats out and see what that gains you.
Nice.
Yeah, you really notice how big they are when you put them next to other stuff... not like the 3HP is a wimpy platform either. Bought the two amps pictured broken, someone had begun repairing that one and given up since the driver card is slagged. I got a couple new driver cards from Shocker Mike so repair should be a bit more straightforward when we get them up to Waterville.
Saw that when I was talking with hispls earlier, sick score
It'll do 157.2-157.4 with the seats out consistently. Peak frequency goes up a little bit and those leather seats really just block sound waves. Probably a bit more in there seats in if I cared to play around with moving them around. Whenever Jason has another day off he can bring by his Termlab and we can do some more testing.
That's awesome, I hope the repairs continue to go smoothly for you. I've heard nothing but good things about Shocker Mike.
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
I have and still do buy quite a bit of audio from there. Great place. Ive never had any issues.. Ever
31
5K
Hi i am planning to upgrade my audio at my rented place, i was using jvc home cinema 5.1 but its extremely bulky, and not so good anymore... i...
CRXBMPN
Moe Bass
CRXBMPN
Maine
wew lad
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
