Small footprint Amp for 1.5 ohm and 1000-1500w
Ok so im kinda in a conundrum. I bought a pair of older 13tw5 3ohm sub and have been running them in an under sized box for a while off of my kicker cx1200.1.
Well fast forward and after a while the box started to come apart. Not a big deal the plan was to replace it anyway and I did. But with the old box flexing it broke the mounting feet off the amp.
To add insult to injury the new box is bigger and the amps now have to go on the back way with my relay panel. Which mean they don't fit well and need to be smaller.
So I need an amp that can do 1-1500w at 2 ohm and still be 1ohm stable while being tiny.
The jl hd1200/1 would work but I really don't want to pay retail for jl
Someone posted a Massive Audio N4 on here earlier it might be perfect for what you need ...
Bass 1200 2ohm or HD3000 2ohm.
That 1.5ohm, if thats DCR, then you want a 2ohm amp, which i've provided, not 1ohm
What kind of dimensions are we talking that you'd like to stay within (footprint)?
Current amps are about 13x8. I have some room to play with I just can't use a massive 3000w amp turned down because it won't fit.
And even with a 1.5 resting resistance I'd like a 1 ohm stable amp because in some cases 2ohm amps are picky with protect mode and low ohm load.
The kicker I have now is a 2ohm amp which has been dynoed around 1500w at 1.5ohm and I've been rounding it at 1.5 ohm for a few years now
I could go with a couple smaller amps gain matched pushing a 3ohm load. Would be looking for about 600w at 3ohm which puts me looking at 800-1000w at 2 ohm amps
Was currently looking at the kenwood excelon xr600-1. I know it rated at 600 at 2ohm but with 90amps of fusing I feel it should be quite underrated
The other option was the alpine x-a90m which is 900 at 2ohm
Your math needs some work..
You say you are using a 13x8 amp but you don't have room for the 3000w amp we recommended?
Our amp is 9x7.5" I don't see how that's bigger?
I like my 3.5K hidden under the driver's seat. Nobody knows where my equipment is. Always thinking it is in the bed of my truck. Nope. Two amps...
14
  • Locked
104
  • Locked
COMPLETED Small 4channel amp
I'm really tempted to grab a 4k db 🤔
19
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
Ponchatoula, La
Louisiana_CRX
    May 10, 2024
3toneEYZ
    May 10, 2024
