Need Box Design/Help for CT Sounds Meso 12
  • 2
LACDPN
Willing to pay someone for some simplified plans/cut sheet or even someone to build a simple box for me in Orange County CA. Will be one 12” ct sounds Meso. I’m not limited by size of the box. Parameters are as follows:
TECHNICAL SPECIFICATIONS:
Sub power: 1500W (RMS) | 3000W (MAX)
Subwoofer size: 12"
Subwoofer type/ impedance: Dual 2 ohm
Voice coil (diameter): 3" (76.2mm)
FS: 37.829Hz
QTS: 0.397
QES: 0.432
QMS: 5.008
VAS: 23.373 liters
SPL: 86.5 dB (@1w/1m)
Xmax: 20mm
Displacement: 0.18 ft3
Magnet weight: 330 Oz
Speaker connector: 12 Gauge
Resonant frequency: 30.5Hz
BOX SPECIFICATIONS:
Sealed: 1.00 ft3
Ported: 1.50 ~ 1.75 ft3
MOUNTING / INSTALLATION PARAMETERS:
Cutout diameter: 282mm / 11.1"
Overall diameter: 328mm / 12.9"
Mounting depth: 196mm / 7.7"
List your dimensions, amp, loading, vehicle and music preference... decaf, low daily, daily, rock/hi-daily or SPL and someone will probably help...
What are you looking for... soundwise?
Honestly not too picky, just looking for loud and low bass. It’s just an occasional weekend cruiser. 1983 Cadillac Fleetwood, so not really limited by trunk space or anything. Later I will have a more custom design made to fit over the contours of the front of the trunk but for now a plain rectangle box in the middle of the trunk pan will do. Mostly hip hop and old school/funk music.
Amp is a hifonics ZXX 3200.1d
In the floor pan... middle of trunk... what configuration works best.... anyone?.. I'd do sub/port rear on this one... 83 pimp daddy Caddy
Wonder how close to 3200 watts the amp gets... or is it MAXX rated?.. 2 ga pwr/grnd huh?.. I'll need a ballpark to port it correctly... I'm guessing 1800 or so at best... anyone?
The 3000 watt version dyno’d at 1810 watts so I’d guess 1800 is a good realistic ballpark. Figured it was cheap power
for occasional use and would push that sub decently.
Wow... that was close... 1800 ok... I'll try tomorrow if nobody else comes thru 1st... with the lower power you've got... wanna try an aero?.. or does it not matter to you?
Doesn’t matter, whatever would be easier as it’s only temporary until I redo my trunk.
Ok then... how much of a decaf fan are you?.. is a 31hz tune low enough?
Honestly I had to look up decaf haha I’ve been out of the scene for a while! But yeah that should be good, definitely gonna have to explore some decaf tracks now
402
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
LACDPN
LACDPN
Orange County
shredder2
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
