How does this design look
JumpinBean23
2016 dart
3 x sundown sa-10s powered off Skar Skv2 1500.1
I just want to make sure I am not missing anything before I start cutting
Any suggestions or ideas are welcome.
Since I can't seem to get the attachment big enough the dimensions are
16h x 40w x 15d
port 14.5 x 3 x 28 for 43.5 in^2 port area
3.08 cubic feet @33 after baffle and woofer displacements
Id go bigger. That amp is going to tickle those subs
yeah that why i asked if he had it and about wiring.. 2 of them be better on that amp.. if he's running at .66 1 idk if skar will do that and 2 thought we could come up with some amps with more power at whatever ohm load he's at., maybe 1.33? skar 2k or xtr 1500 would do good power for those..
2016 dart3 x sundown sa-10s powered off Skar Skv2 1500.1
16h x 40w x 15d
Do deeper than wide if you can..
This^^^IMO... and a little more port won't hurt in case you want to go with a bigger amp... that SK will probably deliver around 14-1500 actual at .66... so... I can model it if you'd like
Feel free to model it if you like, I just don't have the electrical side upgraded yet, so I'm not sure how much it will like that lol. I have not had much luck finding a H.O. alt, so a second battery may be my only option. I haven't ruled out just doing 2, I just have them so i figured i would use them. Honestly it would save space which unfortunately I need to have some left when I'm done. Maybe that is a better way to go?
You still planning to run that amp at .66 ohm?
784
10
840
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
JumpinBean23
JumpinBean23
des moines, ia
JumpinBean23
    Apr 26, 2024
    Apr 26, 2024
