who got some rockville amps
Can you strap the M4?
I'm curious if I should buy one of these for the build I'm doing for my buddies truck (birthday present) or continue with my original plan and use the SQ 2200 I just bought off here.. I'd rather keep the SQ for my ladies car if these are solid enough amps to use.
Who knows. They are T-Fade approved tho
4 gauge inputs //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
during the youtube test .... amp draw= 142A at 1 ohm certified and 153A at 1 ohm uncertified
Features:
Rockville RXD-M4 6000 Watt/3000w Mono Class D 1 Ohm Car Stereo Amplifier With Optical Coupler Technology
CEA Compliant Power Ratings (Rated at less than 1 % distortion) (Use these CEA ratings when matching and comparing with other CEA compliant brands such as Kicker, Rockford Fosgate, etc)
1 Ohm: 1500 Watts x 1 Channel
2 Ohm: 1000 Watts x 1 Channel
4 Ohm: 750 Watts x 1 Channel
RMS Power Ratings: (Use these RMS ratings when comparing with great brands such as Hifonics, Earthquake, Soundstream, etc)
1 Ohm: 3000 Watts x 1 Channel
2 Ohm: 2000 Watts x 1 Channel
4 Ohm: 1500 Watts x 1 Channel
Peak: (The amount of power the amplifier can produce for a split second at the loudest part of a song
1 Ohm: 6000 Watts x 1 Channel
2 Ohm: 4000 Watts x 1 Channel
4 Ohm: 3000 Watts x 1 Channel
Strappable - This amp can be bridged together with another amplifier to deliver twice the power
High-Speed MOSFET Power Supply
Optical Coupler Class “D” Technology
Studio-Grade Bipolar Output Stage Transistors
Now exclusively with “Professional Peak Limiter Circuitry” which guarantees distortion free musical playback at all levels.
Fully Adjustable 12dB / Octave Crossover with Differential Circuitry
Low Pass Filter: 50Hz - 250Hz
Subsonic Filter: 15Hz - 55Hz
Phase Control Switch
Full IC-Controlled Protection Circuitry
Remote Dashboard Subwoofer Control
Fully Adjustable 12dB Bass Equalizer
Mute and Delay Soft Start System
RCA Preamp Line Output
8 Volt Preamp Circuitry
Status Mode LED Indicator
Minimum THD at Rated Power:
S / N Ratio: > 100dB
Frequency Response: 10Hz - 500Hz
Damping Factor: > 220 @ 100Hz
200 Amp External In-Line ANL Fuse Block
Dimensions: (W x H x L) 8.5˝ x 1.8˝ x 17.7˝
4 gauge inputs //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifduring the youtube test .... amp draw= 142A at 1 ohm certified and 153A at 1 ohm uncertified
Features:
Ok. 4 gauge OFC would be fine for ~150 amps of current
michaellane
michaellane
tx
BT7800zz
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
