BC3500 in protect....
1 ohm... i dont like wiring amps down crazy low
hmmmm....your box doesn't look like its made to be super efficient...
ummm. have you tried start the gain down low on the amp. and rolling it up and seeing when it goes into protect?
By the way. Be careful. Sending it into protect too much might pop something on the output (happened to me)
It could still be many many things a sub ground issue rca issue I mean a ton
FML...... i dont understand. it was playing really low volume and gain for a couple seconds then just protected and stayed in it.
it was at low vol when it protected.
**** dude! That's the one you just scooped?? I'd try just one sub and see. If that isn't it.. Ugh... Maybe a battery feeding power back?
what do you mean?
---------- Post added at 03:46 PM ---------- Previous post was at 03:46 PM ----------
what do you mean?
Unplug rcas and speaker wires turn amp on and see if its still stuck if so unplug the battery power wire to amp leave ground and remote turn deck on let caps discharge then plug power wire back up and nothing else see if its came out of protect if not it needs serviced.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
11
You don't understand understand brazilian amps and how finicky they can be about voltage...everything you just said nonsense
13
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
