C and D Batteries 126.7AH each
nicole1230
C and D Technologies Model TEL 12-125
Never Discharged I got them from an Electrical contractor that is doing routine mantainence at facilities that use them for battery back up for their windmill power stations. I have 15 of them.
Absolute mint condition!! I currently have 2 of them running off stock 120 amp alt. and have 2 Orion D5000s and maintain 14.8 and up..
150e.a. plus shipping o.b.o. Local Pickup preferred
Trades welcome. looking for a nice deck and other audio equipment.
Calculate the shipping costs using my zip code (61115) to yours.. AVG is $50 to $75
Ill buy one if you can tell me how old they are. post a picture with the resting voltage with a meter next to it.Whats the total with shipping to 29505? message me
These batteries are 110 lbs each, and as far as comparing Kinetic or xs power to these batteries.. Well put it this way the C and D would pimp out Kinetic and XS on the corner and have to smack them around for not keeping up enough voltage!! as soon as I can I will post pics with retained voltage and dimensions, I just didn't think I would receive as well of a response to them because most like to waste there time adding more and more batteries from stinger, Kinetic, XS etc... Most people are unaware of C and D Technologies. 1 of these batteries will service a real legit 4k system with no problem.
Thanks for viewing
Thanks for viewing
C and D's are the batterys I see the most on here forreal. . They are good batts. Glws
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
nicole1230
nicole1230
Rockford IL
Austin175
Brendon Jenness
    May 8, 2024
    May 8, 2024
