help with tweeter noise (running active)
  • 6
splwj47
so i went active this weekend and ever since i did i get the hum threw my tweeters, it is very annoying and after rewiring everything today to make sure the rcas wernt close to the power wire or the ground wire i still have it. here is a vid of the noise.
here is a pic of everything all wired up. there is only the one spot where the speaker wire is close to the ground and its only for about 6 inches.
maybe from the wires from the car if they are under the rca ,i've had that issue before .also look for a pinched wire somewhere too ,that can cause this
well there is other wiring down the right side of the vehicle, but its just for heated seats/power seats maybe something else to, but i dont know. i know there is no pinched wires i made sure everything was good when i installed the wiring. i never had this noise running passive. but it must be something with that 3rd rca i just installed since it is just threw the tweeters, but it was installed in the same place and the other 2 rcas. so i dont know.
same thing here //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif so i just removed the tweeters and went passsive but still have my mids active
well wtf, at least im not alone lol. if i cant get rid of this whine im just gonna go back passive. which sux.
on my mids you can barely hear it but still its annoying. im going to try and swap out HU units and see if its just my head units because i already tried three rca's
ya seeing as how we have the same head unit it could maybe be something with it. let me know how that works out when u try swapping it out.
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
To my knowledge, I have only heard clipping being attributed to amplifier inputs; power and signal. If your input signal is weak and you turn up...
99
splwj47
splwj47
Great White North
Durango03
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
