tried turning the gain down for the tweets and didnt do anything. it made it a bit quieter but didnt go away, went all the way down with the gain and it was still there. what does this level matching do that u speak of?turn your gain down on the tweeter channel or if your hu has level matching built in turn your tweets down, I had this problem and turned my gains down just a little bit and level matched and it went away
i cant hear no whine comming from the mids just the tweets. could you give a little more insight on the grounding suggestion?the whine is usually signal ground related, which is unaffected by wire routing.
since you have the whine on both tweeters and mids (but more noticeable on tweeters due to the frequency of the noise) it is associated with HU, RCA's, and amp.
could be the amp itself.
could be resistance between HU ground and amp ground. both should be grounded the floor.
could be a bad connection in an RCA. even new ones have failures.
Ok well ill try running 2 new grounds and see if that solves it. Length of the grounds wont mater? So if i run a ground to drivers side firewall and run the amp ground to the floor of the back foot area would be good?ground head unit to the floor, sand away paint, etc. make sure amp and HU are grounded to the same piece of metal - i.e. no tack welds between the two. the floor should be electrically continuous from the firewall to the tire well.
You ever get this figured out?Ok well ill try running 2 new grounds and see if that solves it. Length of the grounds wont mater? So if i run a ground to drivers side firewall and run the amp ground to the floor of the back foot area would be good?
