NEED amp help for New subwoofers
Which amp do you recommend?
  • DP Audio 500 Watts x 2 Car Amplifier, DA1000.2
    Votes: 0 0.0%
  • PYLE PLAM1000 1000 Watts 2 Channel Bridgeable Amplifier
    Votes: 0 0.0%
  • Crunch P1-600.4 600 Watt 4-Channel Amplifier
    Votes: 0 0.0%
  • Total voters
  • 3
I bought two Kicker C84 (10C84) subs and want to know which of the three amps below do you recommend for me.
Subs.
Kicker C84 (10C84)
Amps.
Please help me.
Best budget amp in thag power range in a Pioneer GM-5400t. All you'd really need for those subs, always reliable long as you dont abuse it, and will probably do closer to rated power than the amps you listed.
Can be had from $40-70 depending on timing on ebay.
11
393
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
868
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
killeralibi66jr
killeralibi66jr
Papillion, NE
disturbed471985
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
